[PC] How to ask again to connect?
Hi. How can I make GlassWire Premium ask me again when a program tries to access the internet? Basically, I want to reset GlassWire’s connection requests for programs. I’ve already tried everything — creating new profiles, deleting history, changing the firewall mode — but the apps I once allowed never get asked again. And if I block everything, it still doesn’t prompt me again.
Are you looking to reset this for only certain apps or for all your apps? If you clear the app from the list on the GlassWire Protect tab, it should prompt you again next time it accesses the internet. Go to ‘GlassWire Protect’, find the app in the list and click on the x that appears when you hover over the app name.
Yes, thank you. That’s exactly what I was looking for. I was able to get the programs to ask for a connection again.
The “X” to delete it from the list is very inconspicuous. I couldn’t see it at first glance.
I followed the suggestion above and hoped it would end the multiple blocking issue. I unblocked many items and removed them from the list except for the few I wanted blocked. I restarted my computer and looked at the list again and discovered many items again being blocked in both directions. These were legitimate programs with clean Virus Total results and ones I wasn’t asked to block. This was never an issue on previous versions of Glasswire.
There is a long thread at V3.7.880 blocking tons by itself talking about this.
