I am one of those who requested similar services from Glasswire earlier. What follows is a concrete example of what it now takes me for full network data control.
Today I have a Verizon router which manages all traffic from a wireless antenna. Although it is a “full function” router including Ethernet ports, it only “logs” traffic (unidentified) and is not helpful in understanding throughput let alone managing it. It also has a relatively weak broadcast signal.
Because I’m on an expensive capped plan (30GB limit), overages are $10/GB and the Verizon website reports, while accurate, are typically a day late, I limit the Verizon router to only handling the gateway function. I added a front end Netgear R7000 (recent upgrade) which broadcasts a very strong signal, uses both 2.4 and 5GHz banks, and allows running Genie (Netgear router control) which provides excellent real-time throughput info.
Glasswire, however, provides me with specific information about any activity/application that uses large bandwidth so that I know exactly when and why Win10 hits me with a 3.5GB download. Fortunately, Win10 also provides a limited function “metered connection” control. But despite this control, Win10 can surprise us with large downloads at any time – so Glasswire is my only truly effective defense for controlling home network data usage.
Glasswire as developed today, can only monitor and detect info for PCs on which it is installed. To provide network bandwidth info/control, it would need to be able to access any router on the network – in general, an overwhelming task. Today, Glasswire can only report on a given subnet. To get full network management, it would have to detect activity on any network gateway – which in my case is outside the subnet. But yes, that’s what I want.
Incidently, Glasswire has also helped with numerous other “network” issues. With remote monitoring, I’m able to convince my wife when for some reason her usage dramatically increases. I was able to determine that despite being idle (but running normally), Netgear Genie constantly uploads a stream at the low MB level from one Win10 machine, but not the others. (That is the one machine that is participating in the Windows Insider program. Fix: shut off Genie on that machine when not in use.) I daily check for alerts on each machine for unusual activity and also check the total bandwidth for each machine. So I know within hours of any odd activity and Glasswire gives me the ability to drill down to determine cause.
