I installed some kind of program, after which it started to appear, even when I deleted it, what is it and how to fix it?
Sorry for the issue.
GlassWire has a feature that detects RDP connections.
To turn off RDP this website has details.
Remote desktop is a program or an operating system feature that allows a user to connect to a computer in another location, see that computer’s desktop and applications. It is a is a client application that allows a “client” computer to connect to a “host” computer from a remote location. Users can then control and use the applications and files on the host device from anywhere. Best remote desktop tools which are used globally are: logmein, R-HUB remote support servers, Teamviewer, Microsoft remote desktop etc.
