[SOLVED] QT5core.dll and msvcp140.dll missing and GW won't run
#1
This problem began this morning when I started my computer. Very frustrating! Why did this happen?!
I had to try and reinstall GW two times, and neither time worked. So, I had to uninstall the problem, then do a reinstall, and I still am getting the msvcp140.dll error.
So I found msvcp140.dll elsewhere on my system and moved it into GW folder, and then GW started complaining about missing QT5core.dll again.
What am I supposed to do to fix this problem?
#2
@stealthmode
Do you use any cleaning software to clean your hard drive? Sometimes these types of apps can delete our files. If that’s what happened you’ll have to do a clean install of GlassWire.
The only other thing that could cause this is some kind of file corruption issue. I haven’t seen this reported before and it doesn’t seem to be a common problem.
If you reboot does it help?
#3
It’s none of those.
I found the issue. It’s Visual C++ Redistributable 2015 (x86). I’m on a x64 machine, Windows 10 1709 16299.431. Yesterday it seems that program was updated automatically, I assume beucase it doesn’t show up in my Windows update history. Because it shows an install date of 7/1/2018, but I didn’t install it yesterday.
I realized it also affected MS Word, Excel, etc., after I wrote this thread.
Running modify from the app profile and choosing to repair it fixed the problem.
#4
FWIW, I did a clean install of GW and that didn’t help. I also uninstalled GW, deleted any remaining files and registry entries, then reinstalled GW, and that also didn’t help.
#5
I’m glad everything is OK now. Thanks for the details!
