So I noticed firewall rules data in the Glasswire app and in the Firewall setup are wrong!
blackdesert64.exe was blocked in the firewall setup (showing red on top) while Glasswire was showing it unblocked (I had to press Block/Unblock in the GW app to make it correctly apply the firewall rule)
This is brand new, completely clean installation of 2.3.318 done yesterday
reproduced, selecting “Allow” from notification popup keeps it blocked in the Firewall rule but shows Allowed in GW.
GW does not re-apply the rules after allowing via notification?
Are you using two firewalls simultaneously? If so it can break the API we use so it does not work correctly. Please let me know if you are and I can suggest a quick fix.
If you’re in “Ask to connect” mode, then the app should be blocked by default until you receive a notification to unblock it. So unless I’m misunderstanding I think the behavior would be correct?
I use “Malwarebytes Windows Firewall Control” to lookup Windows Firewall rules but there’s nothing else that controls it
GW seems to automatically create Block rule (as expected in Ask to Connect mode) but after allowing an app through notification popup (that shows on the first connect attempt), GW does not apply Allow rule when I allow the app via notification
Using two firewalls simultaneously that access the Windows Firewall API can break things and will cause all sorts of issues.
With GlassWire, if you don’t want to use our app to block then just turn our firewall to “off” and we won’t touch your rules at all. Unfortunately other apps don’t work this way and it causes all sorts of issues.
You can choose to use GlassWire to block, or you can use another app to block. If you choose to use another app to block please be sure GlassWire’s firewall is set to “off” and never turn it on.
If you choose to use GlassWire to block then go to add/remove programs and uninstall GlassWire along with any other app that accesses the Windows Firewall API.
Now go to the Windows Firewall and choose “restore defaults”.
REBOOT - It’s important.
Now install the latest version of GlassWire with “clean install” and “reset firewall” checked. Everything should work normally now.
Already said, I installed it WITH “clean install” and “reset firewall”, it’s completely fresh installation and it is not applying ALLOW rules when I click “allow” in the Glasswire notification popup
Yes but it does not control anything on its own, it’s just to read Firewall rules,
it does not set anything actively or prevent anything else from setting it up.
It’s a passive app, not active one.
It’s been running with GW for years and I had no issues until recent release
Have you ever used that app to change your rules in any way? If so, GlassWire tries to revert the rules back to protect its blocking, so it could cause this issue theoretically. If that’s the case you should follow the clean reset instructions.
We have not changed anything at all with blocking with this new version and the previous one.
Yes, I know GW stores the rules internally as well.
I only use “Malwarebytes Windows Firewall Control” to delete rules not created by GW, there is no conflict between the apps.
I noticed something is wrong with GW rules because the game would not be able to connect despite I allowed it in GW.
I only used “Malwarebytes Windows Firewall Control”, to read firewall rules, to see the GW rule setup in the firewall. And I noticed it was set to Block (red colour) despite GW is not blocking it (as per screenshot)
After I re-applied manually the rule (by toggling the fire icon in GW), it correctly changed in firewall rules to “Allow” (green colour).
Therefore the verdict:
GW created blocking rule at the start (expected and correct with “Ask to Connect” mode)
After I press “Allow” on the GW notification popup, GW stored internally that the rule is allowed
BUT GW did not re-apply the new rule on the Windows firewall afterwards, it stayed Blocked until I reapplied it manually in the app
therefore - allowing apps through notification popup is either not working or sometimes not working
Thanks for your feedback. We haven’t made any changes to the firewall part of GlassWire in awhile so I’m not sure how this happened to you. Sorry for the issue.
and just to avoid confusion with malwarebytes, I am checking directly in Windows system.
While I can confirm that “Inbound Rules” and “Outbound Rules” are set to Allow as per GW - that looks correct.
I found that the “Monitoring”, “Firewall” section shows the app still being blocked:
So the main issue seems to be with “Monitoring”, “Firewall” section not refreshed.
Could be Windows issue (got 19042.985) or maybe GW
Interestingly, while testing, I deleted the Firefox from GW, yet it still stayed in “Monitoring”, “Firewall” section (and turned into “Blocked”)
“Firefox” is gone from the main window app but it’s not gone from those rules in “Monitoring”, “Firewall”
Even if I delete it!
I think it might be something to do with GW service. Just restarting the service sets the rules correctly
So it’s like the main app window/notifications are setting some things but the service isn’t correctly applying it at the time. Still, the deletion of the app in main GW app is still not clearing it in “Monitoring”, “Firewall”. (and the service keeps setting it back again after reset, it’s like GW service database and GW app database are not in sync)
You can download Malwarebytes Windows Firewall Control from our software library for free. This is a lightweight but powerful software which extends the functionality of Windows Firewall and provides new extra features which makes Windows Firewall even better. It runs in the system tray and allows the user to control the native firewall easily without having to waste time by navigating to the specific part of the firewall. This is the best tool to manage the native firewall from Windows 10, 8.1, 8, 7, Vista, Server 2008, Server 2012.
Doesn’t sound very passive to me. I would heed Ken’s instructions…
again, MWFC does not control any of my firewall rules, I use it to view the rules mostly
it does not have any automatic control (at least I don’t use it this way)
besides, I checked myself and can see that the rules in Windows Firewall itself are incorrect (in “Monitoring”, “Firewall” section), even without MWFC being involved.
At least as a test, I would recommend uninstalling both MWFC and Glasswire, then reboot.
Reinstall ONLY GlassWire, using the GlassWire option “reset Windows Firewall to defaults” option, and see if the rules are correct.
Then finally, add MWFC back, and observe for any possible changes. If MWFC is also accessing the Windows Firewall API, you may have issues with both applications accessing the same API.
GlassWire has a firewall rule protector feature (to protect its own firewall rules) that could cause this issue if another app is making changes to the Windows Firewall API. The recommendations @zzz00m made should solve the problem. If it doesn’t please let me know.
We released a GlassWire update yesterday also but there were no firewall changes.
We could not recreate this issue and nobody else has reported it so far. We will continue to investigate and we appreciate your detailed report.
I’ve been using GW for years with MWFC installed and never had this problem, until recent GW update
but I’ve just tried it and the problem is still there
Windows Firewall still shows the rule GW rule as blocked in “Monitoring->Firewall” after pressing “Allow” on the notification.
The rule is correctly applied on either toggling it twice in GW Firewall UI or just toggling Firewall on/off.
It seems that notification button saves the GW rule in GW internal DB correctly but just does not reload the Windows FW rules.
