Now GlassWire should have dropped some crash dumps on the desktop, did it?
Strange. Let me ask our dev team.
Did it stop logging on a remote server or on the local installation? If itâs remote, then perhaps the remote server is the one that is crashing? If so youâd need to have the debug version there.
I have installed the debug version to both computers, as I said above.
At present, both computers (MA03 and MA04) are remote servers and they are monitoring each other.
MA04 is my primary laptop and MA03 is my secondary.
In similar situations in the past, GlassWire stops logging data on both computers within the same 24 hour period.
I have restarted Windows and GlassWire is now reporting data and all alerts.
When GlassWire stopped collecting data most alerts stopped but I was getting alerts for:
Idle time
GlassWire client connection
GlassWire client disconnection
Did you see any debug logs on the desktop you can send us on any of the computers?
No dumps to the desktop.
I confirmed that the dump files were configured to go to the desktop:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Windows Error Reporting\LocalDumps\GlassWire.exe
DumpFolder=C:\Users\Me\Desktop
P.S. I should have added that the DumpFolder is the same for GWCtlSrv.exe and GWIdlMon.exe. I also checked that they didnât end up in AppData. In the end I also searched for dump file extensions (.dmp, .dump and .mdmp) found no files. -
I display hidden and system files in Windows Explorer so theyâre not hidden either.
Does the debug version of GlassWire keep an internal log that would be useful instead?
If GlassWire hasnât crashed then you shouldnât see any dumps. So now we wait for your GlassWire to crash.
So how will you track down why GlassWire stops logging network traffic and many alerts? It might never crash.
I guess that would mean the update fixed your problem, so itâs not necessary. But letâs give it a week if you donât mind and see what happens.
The problem is not resolved. GlassWire stops logging data. That means the Graph and Usage views are empty. I get none of the usual alerts related to network traffic and applications because GlassWire is not logging any network traffic.
Sorry, I misunderstood.
Please confirm if this is correct:
GlassWire has stopped logging for you currently and your views are empty, but on the desktop of that PC you donât see any debug files? And on that PC you are using the debug version of GlassWire we emailed you? Please confirm.
As I said above, GlassWire stopped logging on my MA03 computer. I got no debug./dump files. I restarted MA03 and GlassWire is working again:
@Remah
Let me discuss all this with our dev team and see what the next steps are. Sorry for the confusion.
1.2.71b has been very stable for me but the data logging problem has now appeared. The Graph view, Usage view and mini viewer show no data:
The problem may be be related to shutting down a computer on one network/adapter and starting up on another network/adapter. With 1.2.71b I stopped shutting down and restarting my computer when I changed locations. Instead, I let my laptop sleep and woke it up on the other network. This week I have gone back to restarting my laptop and the problem has reappeared the second time I did this.
Email us if youâd like to try a version with logs so we can figure out what is happening. Thanks.
I just realized that there is one other different behavior. When I have rebooted and connected to the other network, I have exited Microsoft OneDrive on both occasions. I donât think that is related but Iâve seen stranger causal relationships than this.
Iâm also not a fan of OneDrive and with the latest Windows update I also exited it, so I donât think itâs related but I guess anything is possible.
Weâve crossed wires here.
I am a very happy user of Microsoft OneDrive - 8 years has gone real fast.
âExitâ is the technical term for ending or closing a running process/program. It doesnât mean that I uninstalled OneDrive or disabled its automatic startup.
2. Computers To terminate the execution of (an application): exited the subroutine.
I exited OneDrive for two reasons:
- to reduce network traffic over a very congested WiFi network which I also use to remote-control the computer from my mobile phone.
- to minimize background processing because it might retard a very time-sensitive PowerPoint presentation with many highly-synchronized animations.
I agree with this Remah. âWeâve crossed wires here.
I am a very happy user of Microsoft OneDrive - 8 years has gone real fast.â
But donât think that OneDrive is not a PIA for me! Constant demands to re-enter my pw or to logon again. Constant syncing issues which, when finally resolved with the Anniversary update, then stopped syncing properly (some stuff just gets left out).
Probably my fault for not pursuing this with Microsoft, but there is so much to do that it just frickinâ put up with it.
