Security tab (
This page is accessed from the GlassWire menu | Settings window.
Unlock button (
Alerts (
The Alerts are a list of monitoring features that you can enable or disable.
Only two paid alerts
Only two of the alerts are paid features. If you are using the free edition then the on/off button will say BUY and will take you to the Buy GlassWire webpage:
- Network device monitor alert (
) - Camera and mic monitor alert (
Turn off alerts?
We recommend keeping security alerts turned on unless you’re receiving either too many notifications or a false alarm.
If you turn off an alert in the Settings window then that turns off the security alert permanently so you won’t be alerted to malicious behavior in GlassWire at all.
Five alerts are turned off by default:
While you were awayalert -
ARP spoofing detectionalert -
Bandiwdth overage monitoralert -
DNS server settings monitoralert -
Internet access monitoralert
Note
Turning alerts off does not affect the Show desktop notification checkbox setting. This defaults to checked so turning on alerts will automatically resume desktop notifications.
Each alert defaults to checking the Show desktop notification checkbox.
To save space in this guide, we have excluded the description of the Show desktop notification checkbox for each alert
Prevent desktop notifications?
You can prevent notifications for a single alert or all alerts:
- Single alert: uncheck the
Show desktop notificationcheckbox for that alert - All alerts: uncheck the
Enable tray notificationscheckbox in Settings | Client | General.
Note
Do not turn off alerts unless you want no notifications and no record or history of the alerts.
All Alerts on/off (
Select the All Alerts button to toggle the button from its current state:
Onis green. If it is selected then it does the opposite and turns all alertsOff. -
Offis grey. If theOffbutton is selected then it toggles and turns all alertsOn.
Note
In the free edition, the paid alerts are not affected by the All Alerts button.
Turn the alert on by either:
- selecting the
Network device monitoron/off button - checking the
Notify me about network device activitycheckbox. Two options which can be selected:-
Report all devices joining or leavingradio button -
Report only new unknown devicesradio button
This paid alert lets you know if a network application is accessing either your camera or the microphone.
- selecting the
Camera and mic monitoron/off button - checking the
Notify me if an application is using my camera or microphonecheckbox.
Note
This alert only records network applications. If a program uses the camera or mic but does not access the network GlassWire then no alert will be recorded.
First network activity alert (
The First network activity alert you every time a new application is accessing the Internet or network.
- selecting the
First network activityon/off button - checking the
Notify me if an application has inititated network activity for the first timecheckbox.
Note
- When you first install GlassWire you will receive many of these “new” alerts while GlassWire learns what applications on your system normally use the Internet. These “new” alerts will become rarer over time.
- These first network access alerts are useful because if you suddenly receive a “new” alert from an application that shouldn’t normally access the Internet or from an application you don’t remember installing it could be a privacy or security issue. You can then check the alert in detail and see what application is accessing the Internet, review who or what the app is communicating with, then decide to block it via the Firewall or take some other action.
System file monitor alert (
Alerts you to a system file that has changed that is network related.
- selecting the
System file monitoron/off button. - checking the
Notify me if "hosts" or "lmhosts" files are modifiedcheckbox
Device list monitor alert (
Alerts you to any network related devices on your system that were changed.
- selecting the
Device list monitoron/off button. - checking the
Notify me if a networking device or driver has been added, removed, or changedcheckbox.
Application info monitor alert (
Alerts you to changes with any applications that access the Internet that could be caused by tampering with your computer.
- selecting the
Application info monitoron/off button. - checking the
Notify me if a version, publisher, certificate, or executable of an application has changedcheckbox.
While you were away alert (
Gives you a summary of what network activity occurred on your computer while you were away or while your computer was idle.
- selecting the
While you were awayon/off button. - checking the
Show me a brief summary of any signficatn network activity that occurred while my computer was idlecheckbox.
ARP spoofing detection alert (
Looks for and reports ARP spoofing. ARP spoofing may allow an attacker to intercept data, modify your Internet traffic, or stop your traffic all together.
- selecting the
ARP spoofing detectionon/off button. - checking the
Notify me if my MAC address associated with my IP address was changedcheckbox.
Bandwidth overage monitor alert (
Go to the “Usage” tab and click the “Options” on the left side to set an alert once you hit a certain bandwidth level.
- selecting the
Bandwidth overage monitoron/off button. - checking the
Notify me if this computer uses a certain amount of bandwidth over a specific time periodcheckbox.
Note
- The default overage threshold is 150GB per calendar month.
- You cannot exclude external network traffic because bandwidth is normally limited on your Internet connection.
Time period dropdown
The default Time period is Month.
Start day dropdown
The default Start day is the 1st day of the period.
Traffic amount input
The Traffic amount number can be a three digit number up to 999.
The default number is 150.
Traffic amount unit dropdown
The Traffic amount dropdown units can be set to Megabytes, Gigabytes or Terabytes.
The default unit is Gigabytes.
Traffic type dropdown
The Traffic type monitored can be In, Out or Total which is the total of In + Out.
The default is Total.
Exclude local network traffic checkbox
You can Exclude local network traffic by checking the checkbox.
The default is unchecked so the monitor includes local and external network traffic.
Proxy settings monitor alert (
Alert you to proxy use or changes.
- selecting the
Proxy settings monitoron/off button. - checking the
Notify me if my proxy settings were changedcheckbox.
DNS server settings monitor alert (
Alerts you to DNS changes on your system.
- selecting the
DNS server settings monitoron/off button. - checking the
Notify me if my DNS server settings were changed or updatedcheckbox.
Internet access monitor alert (
Alerts you to Internet access changes on your system.
- selecting the
Internet access monitoron/off button. - checking the
Notify me if my internet connection was disconnected or reconnectedcheckbox.
Remote GlassWire connections alert (
If you enable the remote access feature this alert lets you know when you connect to your server or computer remotely with GlassWire. Remote monitoring is popular with GlassWire users who manage remote servers for work, gaming, etc…
- selecting the
Remote GlassWire connectionson/off button. - checking the
Notify me of remote GlassWire connectionscheckbox.
Suspicious hosts monitor alert (
GlassWire keeps an up to date list of known suspicious hosts and alerts you if you contact one. Suspicious hosts are often related to botnets, malware, and other malicious behavior.
- selecting the
Suspicious hosts monitoron/off button. - checking the
Notify me if an application initiated a connection to a suspicious hostcheckbox.
OK button (
The OK button will accept your changes to all settings in all tabs of the Settings window.
It also closes the Settings window.
Cancel button (
The Cancel button will abandon all your changes in all the tabs in the Settings window.
How to improve this topic
This is a wiki post, like all the other #how-to topics, so feel free to improve the content. Just leave a reply explaining what you’ve done and why it makes sense to do it that way.
it so we can see what is most effective.
