Settings dialog window (
This dialog window is accessed from the GlassWire menu.
Three tabs of settings (
There are three tabs to access different groups of settings:
Clientis for settings related to this computer and to allow the GlassWire UI to access other GlassWire servers running on other computers. -
Serverto setup GlassWire as a server that can be accessed by other computers running GlassWire. -
Securityincludes settings for all the GlassWire alerts on this computer.
Closing the Settings window (
The Settings window can be closed in three ways:
- Save any setting changes:
- Select the
OKbutton to save any changed settings…
- Select the
- Abandon any setting changes:
- Select the
Cancelbutton to abandon any changed settings. - Select the
Xat the top right corner of the window to abandon
- Select the
Client tab (
The Client tab has settings for GlassWire on this computer.
Under the Client tab there are two buttons to view pages or sub-tabs if you like to think of them that way.
Generalfor the main GlassWire settings apart from alerts:
GlassWire Menu | Settings | Client | General -
Remote Serverto add another computer which you want to monitor from this computer:
GlassWire Menu | Settings | Client | Remote Server
Server tab (
The Server tab has settings to setup GlassWire as a server that can be accessed by other computers running GlassWire.
Under the Server tab there are two buttons to view pages (or sub-tabs if you like to think of them that way).
Generalto specify the ports to be used to access this server
GlassWire Menu | Settings | Server | General -
Remote Accessto specify security settings so only authorised clients can access this server.
GlassWire Menu | Settings | Server | Remote Access
Security tab (
GlassWire has a range of alerts that you can be notified about. The Security tab allows you to turn them on/off, enable/disable a desktop notification, and specify other other settings for each alert…
OK button (
The OK button will accept your changes to all settings in all tabs of the Settings window.
It also closes the Settings window.
Cancel button (
The Cancel button will abandon all your changes in all the tabs in the Settings window.
How to improve this topic
This is a wiki post, like all the other #how-to topics, so feel free to improve the content. Just leave a reply explaining what you’ve done and why it makes sense to do it that way.
it so we can see what is most effective.
