Problem with connection after update / no Trial-Elite-Version available
#1
Hi,
I have already used the Glasswire 1.X Versions and also the first 2.x Version on other Devices.
It was perfect, it was running without any errors.
Today I have installed the newest version of Your Software. First of all I had a problem after the installation with “Qt5core.dll” and one more .dll-File.
I have downloaded Microsoft Visual C++ Redistributable 2017 once again (I had already installed it before the download and installation of the newest Glasswire Update/Version).
Then the error disappeared. But then I had a new problem – Your Glasswire-Software refuses to start; the message was “Attempt to connect to local server” and “… 1…2…3…”. After few minutes I could read on the screen “Glasswire service stopped running”.
The next activity I have done was to unistall the Glasswire Software + Windows Firewall Reset and the instruction of Your “Clean Install” from Your GlassWire Forum.
If I have today restarted the whole procedure (download and install of the newest Glasswire-Version)…the program where just okay, it was running, but not in the Elite-Trial-Version (7 days).
I had never before installed Glasswire on this PC, I would to test this Device and a Remote Server in the Elite-Version before I would buy it.
So what can I do now?
Best regards.
Things Scan lasts a long time
#2
@AdMed
Please email me with a link to this thread https://www.glasswire.com/contact/ so I can give logging instructions to find the cause. Thank you for your help in finding this problem.
#3
@Ken_GlassWire I will send you immediately.
Thanks!
#4
@AdMed
We replied, please check. Thanks!
Remote Server Error
