We need some help to solve this. Could you run the Windows Command Prompt as “administrator” and type “net start gwdrv” (without quotes). What message will you see on this command? Normally it should say “The requested service has already been started. More help is available by typing NET HELPMSG 2182.”
Also please add the log.conf file to the c:\programdata\glasswire\service folder. Please put following string to the log.conf:
log_path=c:\programdata\glasswire\service\log
Try to restart the Glasswire service. The log.conf file enables the logs, which will be stored at the c:\programdata\glasswire\service\log folder. Please provide us the logs, this will help us a lot in resolving this issue.
The command “net start gwdrv” gives me a message (in french) saying that the service name is invalid. Is this because my windows is a french version maybe ?
I think we have localized the issue with your assistance, but could you please help us again.
Please open the C:\program files (x86)\GlassWire\driver\x64\ (or x86 depending on your platform). Create a .bat file there with the following instructions:
@ECHO OFF
set catfile=gwdrv.cat
set drvfile=gwdrv.sys
set inffile=gwdrv.inf
echo Installing driver
echo Copying Bins from .\ to %WinDir%\System32\Drivers\
copy %catfile% %WinDir%\System32\Drivers\%catfile%
copy %inffile% %WinDir%\System32\Drivers\%inffile%
copy %drvfile% %WinDir%\System32\Drivers\%drvfile%
echo Done
echo Registering driver
RunDLL32.Exe syssetup,SetupInfObjectInstallAction DefaultInstall 128 %WinDir%\System32\Drivers\%inffile%
echo Done
net start gwdrv
Save the file and then run it as Administrator.
What will be the output? If everything is ok, it should say:
Installing driver
Copying Bins from .\ to C:\WINDOWS\System32\Drivers\
1 file(s) copied.
1 file(s) copied.
1 file(s) copied.
Done
Registering driver
Done
The GlassWire Driver service was started successfully.
Just for the records (if anybody has the same problem as me when running the bat file), I just had to prefix the call to rundll32 and net with %WinDir%\System32\ path (maybe an environment variable not set at my side).
So the bat file I used is the following:
@ECHO OFF
copy %catfile% %WinDir%\System32\Drivers%catfile%
copy %inffile% %WinDir%\System32\Drivers%inffile%
copy %drvfile% %WinDir%\System32\Drivers%drvfile%
echo Done
The latest update works perfect! All previous problems I reported no longer occur. Thanks Glasswire team and those in the thread that helped provide information.
You can try uninstalling PCTools temporarily and see if it solves the problem but I have a feeling it’s not related. Please try the release coming tomorrow and let me know if it solves it for you.
Also the Problem here still updated to new version but it did not fix the problem…
Problem came over night… started pc and it did not work anymore… no installs or updates done … just crashed app.
Right now on 30b but all versions had it before (since 24 for me)
If you see anything please email us a crash dump that can be found at C:\Windows\Minidump. Our contact email for “bugs” is here: https://www.glasswire.com/contact/ Thanks!
No bumpfiles there.
Stucking there since pc bootet… Uninstalled fully and reinstalled http://puu.sh/cO68W/55e529c260 .png
had to add the space because i’m “new”
ty
Greets
Try to uninstall GlassWire, rename the C:\ProgramData\GlassWire folder and re-install GW;
Check the state of the GlassWire service on the Task Manager’s Services tab – it should be running;
If you have a third party firewall please try turning it off.
If the problem still persists and the GlassWire service is running, please try to shutdown the GlassWire application (tray icon menu->exit) and then launch it again.
