Remote Server page (
This page is accessed from the GlassWire menu | Settings window.
Server List field (
The Server List lists all remote servers that you might want your GlassWire client to monitor.
Add New Server button (
Select the Add New Server button to input the server details.
- Input the
Namewhich can be whatever you like but you will only be able to see the first 19 characters in theServer List. - Input the server
IP addresswhich is not formatted here so ensure that you use the correct format (###.###.###.###) - Input the server
Passwordif any password is set at the server. - Check the
Enable connectioncheckbox when you are ready to connect to the server.
Note
- To delete a server record move the mouse pointer over the server record in the
Server Listand select the grey X that appears. - The free edition only allows one remote connection so GlassWire reminds you of this by displaying
Buy GlassWire to add More Serverswhen you start to add your first server.
OK button (
The OK button will accept your changes to all settings in all tabs of the Settings window.
It also closes the Settings window.
Cancel button (
The Cancel button will abandon all your changes in all the tabs in the Settings window.
How to improve this topic
This is a wiki post, like all the other #how-to topics, so feel free to improve the content. Just leave a reply explaining what you’ve done and why it makes sense to do it that way.
it so we can see what is most effective.
