General page (
This page is accessed from the GlassWire menu | Settings window.
Network (
Server default listening port input
The default Server default listening port is currently 7010.
Note
If you change the Server default listening port then GlassWire calls this a custom port. You will have to append the custom port numbers to the Server IP address at the client computer, e.g. instead of 192.168.1.12 you will have to append the custom port number 192.168.1.12:7012.
Port range begins input
The default Port range begins at 7000.
Port range ends input
The default Port range ends at 8000.
Server info (
Server listening port
The Server listening port will show the current setting.
Remote Access State
The Remote Access State should be Allowed to show that you can connect.
Remote clients online
The Remote clients online should show you how many remote clients are connecting to your server.
OK button (
The OK button will accept your changes to all settings in all tabs of the Settings window.
It also closes the Settings window.
Cancel button (
The Cancel button will abandon all your changes in all the tabs in the Settings window.
How to improve this topic
This is a wiki post, like all the other #how-to topics, so feel free to improve the content. Just leave a reply explaining what you’ve done and why it makes sense to do it that way.
it so we can see what is most effective.
